Please show example of disk streaming
The book mentions on 15-7 LabView Express about disk streaming. It states to put the Open/Create/Replace File VI before the loop and the close file vi after the loop. I wired the ref numbers through the loop but it only records the last data. How can I get this to record each iteration without the overhead of file/open close?
Troy P
Pella Windows and Doors
(2,968 Views)
You probably have not wired a True constant to the "append to file?" node of the write to file vi. I have attached an example which streams the current iteration to file until the Stop button is pressed.
I hope this helps.
(2,960 Views)
Thank you John R for the quick reply. It turned out I didn't even have the write file vi in the loop. Your example was awesome and a great help. Happy Holidays! Troy
(2,933 Views)
