Hi Lauren,
There are a couple of ways to proceed.
You can open and read the file. It should be a string of ASCII representation of the values stored (weird characters). To look at them, place an indicator where you read the file. On the front panel, right-click the indicator and select HEX Display.
To manipulate the data, you can type cast it into as a integer... Then place it into a 2D array...
Better method:
In the Functions Palette, select File IO, then Binary Files vi, and place the "Read from I16 File.vi"
You can wire directly to the output called "2D array".
(much simpler than above). You can then wire this into "array to Spreadsheet String.vi"..
Actually, an example may be simpler to explain...
(especially on a Friday
;o)
See attached example:
