[Please take a look]Any way to improve?
I ended up having the same functions twice in order to graph and extract a portion of them. However, since I am using two cursors to extract a portion of the two graphs, I need to select the same portion on the two separate window..which is quite annoying. I am wondering whether I can have two data streams on a single window without getting errors.
Please comment on the vi and if it is possible, please modify them or send a pic so that I can understand how to change them. (me=LV newb lol)
Also, let me know if there is better way of doing this.
Thanks. ;]
(2,400 Views)
Well, allow the user to only drag the cursors in the first graph and use the indices for both array subsets.
If desired, you can programmatically move the cursors on graph #2 to reflect the same positions.
See attached small modified example. Is there a reason you are using local variables? A simple wire seems sufficient. (I cannot run your example, because I don't have DAQ hardware. What determines your loop rates?).
(2,400 Views)
