Plot 3dsurface Line and X,Y,Z Axis ....
Hi:
I put my test data to 3dsurface funtion in LabVIEW as below picture. (3dgraphy-Labview)
1.How to add 3dsurface Line and X,Y,Z Axis as below sample picture?(3dgraphy-Sample)
2.How to show color specturm bar ?
Thank you very much.......
Message 1 of 24
(6,520 Views)
Hi vicent99,
1) change the plot style... (cwSurfaceLine-mode). Usually the 3d plot shows all 3 axis, so you can switch them on using property nodes for the graph...
2) You can make your own bar, perhaps using an array of colorboxes...
Edited:
to 1) switching on the XYZ-axis will show the axis outside of the graph, but will not show just vectors inside the graph...
Message Edited by GerdW on 12-05-2007 11:43 AM
Message 2 of 24
(6,496 Views)
Hi GerdW :
Thanks!
1)I set plot style to "cwsurfaceline"  the plot picture as below....(3dgraphy-3dsurface-line.JPG)
   How to set surfaceline link "3dgraphy-Sample"?
2)I add X-Y-Z axis to the plot but the axis not in plot center (on the bottom). (3dsurface-Axis-add.JPG)
  How to set axis on the center link "3dgraphy-Sample"?
  How to add axis caption beside theaxis link "3dgraphy-Sample"?
  How to remove grid x,y,z ?(just show axis only.....)
3)How to show color spectrm like spherical coordinate ? (Same r -->same color,like "3dgraphy-Sample")
I have tried maby times about these requirement.......but still not successful ........
Message 3 of 24
(6,485 Views)
Hi Vincent,
Can you slow down and be more precise with your questions?
I understand the 3d graph but I am not following your questions.
Trying to help,
Ben
Message 4 of 24
(6,479 Views)
Perhaps the following example may be of some help: http://zone.ni.com/devzone/cda/epd/p/id/468
Message 5 of 24
(6,451 Views)
Hi:
I find a picture from Internet.....That is my target....
Do every one know how to plot the data to 3D surface as the picture?
Thank you.....
Message 6 of 24
(6,377 Views)
Vincent,
Please post using your native language.
I still do not understand your request.
Ben
Message 7 of 24
(6,365 Views)
Hi Ben:
Thanks!
1.附件為我量測到之數據.(BOOK1.csv)
   Attached file is my measurement raw data.
2. 我已將其數據在LabVIEW中畫出3D圖形(Current.jpg).
  I have ploted these data to 3D plot on LABVIEW.(refer above picture)
3.我的疑問是:
    -如何顯示顏色分怖是依據距離 原點(0,0,0)之位置來分佈...目前我做到的是依據 z 軸值的大小來分佈 .
    -如何繪表面曲現線
  我之前附之圖片是在網路上找到的(Target.JPG),也是我希望達到之目標....
 Thanks!
Message 8 of 24
(6,337 Views)
Hi Vincent!
While waiting for someone to translate, I will guess that that you want your 3d plot to appear as a sphere.
You can shut-off auto-scaling of the axis manually at
Right-click >>> CWGraph3D >>> Properties >>> Axis >>> Range
OR
you set the ranges programatically
See here for an example were I used the above code.
I hope this helps!
Ben
Message 9 of 24
(6,317 Views)
Dear Ben:
Yes!I want show data on 3d plot to appear as a sphere..
 I don't know how to do this.....
Thanks!
Message 10 of 24
(6,285 Views)
