Plot a 1D array and a 2D array in a single plot/chart.
I have a 2D data of an image of size 1000x1024 and I have a 1D graph of size 1x1024. How can I plot both of them in a single plot/chart? Both the data are in the form of an array.
Message 1 of 12
(6,171 Views)
Use the PlotImages.Back property of an XY-graph to plot the image: https://zone.ni.com/reference/en-XX/help/371361R-01/lvprop/mxsiggrph_plot_imagesback/
Certified LabVIEW Architect
Message 2 of 12
(6,138 Views)
But the data which I have is in 2D array form and the images are generated from a machine and not imported from a file. So every time the code runs, there will be a new image. That's why I need to plot it as an array on another array.
Message 3 of 12
(6,126 Views)
"2D array form". Is it an RGB image represented as a 2d-array? Then just use "draw flattened pixmap". No need to import a file.
What do you mean by "plot an array on another array"? Can you show us some data and what you want to do, or some code, or pictures?
Message 4 of 12
(6,121 Views)
In the attached image, the generated image can be seen above and the plot below. The image is obtained from the machine in the form of pixel values and then I have done coding to obtain the topmost edge in the image. Now I need to visualize that graph plot over the original image to see how well is the edge detected. I hope this makes it clear what I want to do.
I also attached a VI - trial_plot. It consists of both the image and the plot data.
Message 5 of 12
(6,116 Views)
Why not add the new graph to the 2D one?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 12
(6,108 Views)
I tried adding using the build array, no results. I only see the image and when I see into properties of the plot, I don't see the tab of Plots to change the color of the line graph. How would you suggest to add it?
Message 7 of 12
(6,105 Views)
You can r-click and Show Legend, if memory serves, there you can set plot properties as color.
/Y
Qestit Systems
Message 8 of 12
(6,102 Views)
I tried and I didn't see any such option. Could you please show it in the attached VI?
Message 9 of 12
(6,097 Views)
Accepted by topic author yp96
Ah, its an intensity graph. Rarely had to use those. I have attached the simplest solution. Just overlay the XY-graph and make it transparent.
Message 10 of 12
(6,094 Views)
