Plot an XY graph with Y axis being a 2d array
I want to plot an XY graph where X axis is constant but y axis is 2d array. On searching, I found this
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwYCAW&l=de-DE
but this is not what I want because here the 2d array size is 2 by 1 whereas mine can change and is values like 84 by 1 or similar. So i cant sit and program like the above link for 84 arrays. So is there any other way to do it. Thank you.
(880 Views)
Accepted by topic author govindsankar
Hi govindsankar,
after all those threads you still don't provide some example data with your questions nor do you show any effort (aka VIs) of your own…
What I get from your message is something like this:
(864 Views)
