Plot column data
Hello
I have one file and from that I want to plot XY graph.
So problem is that I want to set first column as a x-axis and other column as a y-axis(any one column). Y axis should be controllable column.
i.e. If I selected 45 column then xy graph should plot between 1st column and 45 column as Y-axis.
Please help me.
(2,855 Views)
read the excel sheet and index the array
look at the examples how to use the xy graph
here is one way:
Greetings from Germany
Henrik
LV since v3.1
(2,851 Views)
