Plot excel data onto X-Y graph with time stamp
Dear all, I have the same set of data but it is saved in excel format instead of text file now. However i think the column data are separated by tab, i have tried to write some codes but it dont seem to plot out the graph properly. I have no problem ploting out data in text file but not this excel file. Can anyone help out to plot this graph with timestamp?
(3,788 Views)
That is not Excel data. It is a text file and you say you having no problem with those so I don't understand why you are posting this question.
(3,778 Views)
Dear Sir,
I have two files in fact, one save using text and another using xls format. I have attach the text file only. May i know how can i do the plotting for this data? The data are separated by tab this time.
(3,771 Views)
I still don't understand your comment 'I have no problem ploting out data in text file'. The Read From Spreadsheet by default uses a tab separator so you should have no problem reading the file. Post the code you have already written so someone can see where your problem is.
(3,760 Views)
