07-20-2005 08:49 AM
07-20-2005 10:04 AM
07-20-2005 10:14 AM
I have tried to set that to 604800 (number of seconds in a week) but it still seems to only do 2 hours, but I have not let it run for that long to really see what it does so I will try to set it like that and see what happens.
07-20-2005 10:21 AM
07-20-2005 10:28 AM
07-20-2005 11:59 AM
There are a few things you need to set.
You said you're plotting once every 2 minutes. I assume this means that you're wiring a value into the chart only once every 2 minutes. This is important because charts calculate the time based on the starting time (offset) and the difference between each 2 points (multiplier).
So:
07-20-2005 01:41 PM
