Plot new axes on intensity graph
I am trying to draw XY axes through an arbirtary point on an intensity graph. I can draw two lines across the image (following posts like that linked below), but they don't seem to actually endf up a the coordinates I spesify. I know that I need to correct for the fact that the vertical scale increases from top to bottom, but how can I draw lines at the (x0,y0) position I spesify? It seems that the lines are overlaid on the image, but not linked to the actual axes of the intensity graph.
http://forums.ni.com/t5/LabVIEW/overlaying-XY-line-onto-intensity-graph/td-p/398963
Message 1 of 12
(6,091 Views)
you can use PlotAreaSize:
Message 2 of 12
(6,046 Views)
Thanks. I'm still confused. I see that bounds was wrong because it found the size of the object, not nessesarily the plotting region. But PlotAreaSize seems to do the same thing. I want to draw a line at say (100,150) on the intensity graph, independent of the size of the chart.
Also, the options I get under the property node PlotAreaSize in my Labview appear to be different than in the picture you provided.
Message 3 of 12
(6,042 Views)
no PlotAreaSize - size of plot area only, Check it.
You need size of pixel in axis unit. So, you take plot size (pixels) and divide it to axis size.
You  can select any property in any order. You need axis size.
Btw, if your axis start not from 0, take range maximum and minimum.
Max-min=axis size
Message 4 of 12
(6,038 Views)
Thanks so much. i think I understandnow.
Now I'll try rotating the lines by a user-spesified angle. 🙂
Message 5 of 12
(6,035 Views)
Degrees to radians and sine+cosine.
Or XY to polar -> change angle -> polar to XY
Message 6 of 12
(6,031 Views)
Thanks. I ended up feeding the points into the 2D Cartesian Coordinate Rotation VI, but it's not right. I think this is because it is rotating about the origen and not the cursor point. I tried translating back to the origen, rotating, then translating back, and it seems to have a similar problem (forgive the dumb way I did that).
Message 7 of 12
(6,018 Views)
Accepted by topic author teroenzaa
but you need made "vertical mirror"
Message 8 of 12
(5,996 Views)
I don't understand where  the "vertical mirror" comes in. I see that you convert to polar coordinates then add the angle (much more clever than my solution).
Message 9 of 12
(5,988 Views)
In my vi point(0,0) at left upper corner. You need left down.
Message 10 of 12
(5,955 Views)
