Plot serial data to chart
I would be surprised that the code you posted would have worked.  Why did you not build onto the example I provided?  (why do I bother creating proper examples???)
And adding another While Loop inside a Case Structure spells t-r-o-u-b-l-e.  You claim that it works?
I'm curious...  Can you post that working code?
Message 11 of 12
(1,415 Views)
I altered my old code and it is actually very similar to your example.
Before I only had one while loop and now I have two.
Just like in your example, I added the loop around the inner case structure.
Message 12 of 12
(1,405 Views)
