Plot the angular position of two motors
With reference to my previous message, how will I generate an array of X & Y values from graph to be feed into the bundle.
Message 11 of 18
(1,819 Views)
Share the Code Snippet/VI Which you have tried so that it will be easy to provide Idea on how to proceed?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 18
(1,815 Views)
I have created 3 VI, but unable to understand which way to proceed. As adviced I have attached the VI's below.
Message 13 of 18
(1,804 Views)
But it didn't help much
Message 14 of 18
(1,796 Views)
hi, you didn't provide any solution to my problem. How will I generate an array of data from waveform?
Message 15 of 18
(1,749 Views)
Hi reshmi,
none you of your VIs show you really understand how to THINK DATAFLOW!
When you only want to use ExpressVIs stick with them:
Otherwise learn to handle the correct datatypes:
- your DAQAssistent reads "1 sample on request", so you should convert to a scalar value instead of waveforms!
- how to create plots in a XY graph is explained in the example VIs found in the example finder…
Message 16 of 18
(1,748 Views)
Sir thanks for your suggestion.But I have already implemented this VI. But nothing is displayed in the waveform.
Also I have converted the dynamic data from DAQ to array of waveform & fed individually to X & Y input of XY Graph. But still the same thing. No output.
Message 17 of 18
(1,738 Views)
Hi reshmi,
did you configure the BuildXYGraph to NOT clear the data with each call?
Doing it explicitely looks like this:
I replaced your DAQAssistents by Random functions to simulate data generation…
Message 18 of 18
(1,734 Views)
