Plot the time-domain wave PXI-5660
I want to plot the time-domain signal on the exactly on the way it leaves the signal generator, frequency, amplitude etc... Im using PXI-5660. Is it possible?
Valerio Nobre
(2,404 Views)
Valerio,
What software are you using? I am assuming you are using LabVIEW but which version? Whichever version you have there should be example programs that installed with your specific driver...they can be found at HELP>>Find Examples. I don't have your specific driver loaded so I will not have the examples but if you do not see anything that helps you reply and let me know what version of LV you are using.
-Brett
(2,395 Views)
