Plotting 4D data using 3d picture control
I am using 3d picture control in my vi to view the data plotted at different locations.The 3d picture contains axis as I generated it using Create 3D axis vi But I am not able to get the gridlines on the axis to be shown on it with marker spacing(like on a 2d graph).How can I get the grids ?
I am attaching the vi in which only axis is there with data points plotted on it.
Regards
Vijayab
(3,587 Views)
Basically, to have the grids you have to 'draw' the grids yourself.... There isn't a lot of help from the 3D picture control at the moment for this task.
However, if you are able to 'drill' into the "3D Graphs", you can have some functionalities that you can use to create the graphs. In attachment you have some VIs that you can look inside and see how you can create your own grid.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,483 Views)
Hi Barp,
Thanks for your response 🙂
(3,460 Views)
