Plotting Array of clusters
I am trying to graph data from an array of clusters. It is a 1D array with N clusters of 3 elements. Attached is a minimal working example.
Each case structure denotes channels 1,2,3,4,9 which creates a cluster of 3 elements. And this is iterated over N=5 times as shown in the Master For loop. I need the data generated from each case structures to be appended to the plot. Whereas now with my code, it is appending data collectively from all case structures 5 times; which is wrong.
Each channel data (containing 3 elements) should be plot over 5 iterations, and since there are 5 channels with 3 elements in each channel the total # of plots should be 15. How can I plot them in a single graph ( later I will add boolean logic to hide/show each channel data because 15 line plots in single graph is a lot)
NI System Configuration:
- NI PXIe-1071, 4-Slot 3U PXI Express Chassis , 1 GB/Slot throughput, Part Number: 781368-01
- NI PXIe-PCIe8381,x8 Gen2 MXI-Express for PXI Express Interface,3m, Part Number: 782522-01
- PXIe-5160 PXI Oscilloscope, 500 MHz, 10 bits, 2.5 GS/s, 2 Channels, 64 MB, Part Number: 782621-01
- Astronics PXIe-1209 2-Channel, 100 MHz PXI Pulse Generator, Part Number: 785033-01
(4,553 Views)
Accepted by topic author asukumari
Correct me if I am wrong.
You have 5 channels with 3 signals in each channel. You acquire 5 times, so in the graph You want to see 15 graphs: channel1.signal1, channel1.signal2, channel1.signal3, channel2.signal1, ...
You can do it using shift registers and in-place-element in Your secondary loop.
Colect dataColect dataPrepare graphPrepare graphInterfaceInterface
(4,512 Views)
Simply put all data in the plot, and let the plot show\hide them. Either from your code, or let the user select the visible plots...
(4,510 Views)
Ok I think that's the way to implement it then. Thank you!
(4,474 Views)
This really is such an awesome code! Thanks!
(4,474 Views)
