Plotting XY graph with two values and time
Then stop using that one.
Use Spreadsheet string to Array with comma as the delimiter.  Use a For Loop to iterate over each row of the 2-D array.  Now inside that For Loop, you have a 1-D array that is one line, and each item is an element between the commas.  Use Index Array to break apart that 1-D array into individual elements.  Convert each item of that array to strings or numerics or whatever as needed.
Message 51 of 55
(824 Views)
Iv'e been using a template which altenbach posted, which is using a scan from string function. I thought this was the best option.
Message 52 of 55
(823 Views)
It probably was the best option the way your problem was first described.   But now you have a different, more complicated data structure as Altenbach said in message #33.  It may be possible to come up with a scan from string that will work.  Or the best option now might be to approach the problem from a different angle.
Message 53 of 55
(814 Views)
I agree. you might just want to read it as a 2D array of strings using "read from spreadsheet file" then loop over each row, indexing out the relevant elements.
Message 54 of 55
(811 Views)
Could you please post an example of this?
I tried finishing the scan from string version, the VI below is how far I got with it. I get 'error 1' when I try to run it.
Message 55 of 55
(800 Views)
