Plotting different sets of XY coordinates on a single plot
I've 2 sets of XY coordinated. Each of the XY coordinated are running randomly, I'm wondering if it is possible to place the XY plot of one set and the other set of XY values together in one single plot? So in the end there will be two dots appearing on the XY plot.
If anyone have any idea, please kindly advice me on this. Thanks
From
Donny
Message 1 of 20
(4,164 Views)
Hi Donny
No Problem - each Point has to be wired into the build cluster-function (x/y-value). All resulting point-clusters are then wired to the build array function. This output is then wired to the xy-graph.
Just have a look at the attachement.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 20
(4,156 Views)
Forgot the attachement...
Using LV8.0
Message 3 of 20
(4,156 Views)
hi,
what if i have 1 set of XY value in a True case and the other in a False case, am I able to display the 2 sets of XY values on a single plot?
From
Donny
Message 4 of 20
(4,152 Views)
Yes, you can, if it is not in the same case-structure. If not, just wire the data out of the case-structure.
Using LV8.0
Message 5 of 20
(4,150 Views)
hi,
I can show both of the XY sets of values. But in my program, i wish that for the first time when I click on the selector, the 1st set of XY values will appear, then when i click on the selector again the 2nd set of XY values from the different chart will appear on the plot together with the 1st set of XY values on the plot.
So now there should be two dots on the plot. One dot belonging to the 1st set of XY values from the first chart and the 2nd set of XY values from the second chart.
Do you think it is possible to do it? Could you kindly give me some pointers.
Thanks alot
Message 6 of 20
(4,137 Views)
If you save the vi for LV 7.0 I'll have a look at it..
Using LV8.0
Message 7 of 20
(4,130 Views)
i've only Labview 7.1 on hand, how can i save it to the Labview 7.0 version?
Message 8 of 20
(4,128 Views)
Menu File >> Save with Options. In the appearing dialog you can select "Save for previous". If select you can choose the version on the right side.
Using LV8.0
Message 9 of 20
(4,126 Views)
ok got it...it is now in ver7
Message 10 of 20
(4,122 Views)
