Plotting graph not respect to time
I want to plot a graph which the Y-axis is the BER and X-axis is the Received Power. I want to write an automate application where I will reduce or varies the Received Power(or transmitted power)with time of a laser and see the variations of the BER. All the graphs VIs in Labview are respect to time(x-axis). How can I plot this BER versus Received Power graph?
(2,388 Views)
The X-axis is just labeled 'Time' as a default. You can input any data you choose and change the label accordingly.
Randall Pursley
(2,380 Views)
