Plotting intensity graph by flipping axis's alternatively
I am getting 1D signal from a sensor which I am trying to map into intensity plot. I used the example because real vi is big and also need separate driver for the operation. However, the output from the sensor is similar (1D array) which I need to arrange according to what I've described before.
I can not change the way data is coming. I am almost there, just the arrangement problem. Will you please give me some suggestion on how to reverse every other row without flipping the whole array?
Message 11 of 12
(727 Views)
If I understand you correctly, you want to reverse the order of every other row within your 2-D array.
If that is a correct statement, here is the solution to a previous forum post that should be helpful:
http://forums.ni.com/t5/LabVIEW/reverse-2d-array/td-p/1464806
Rachel P. | Applications Engineer | National Instruments
Message 12 of 12
(688 Views)
