Plotting more then one waveform, change offset for one only
just like tuning the one on the oscillescope
but it will only move up or down for one waveform, instead of changing all...
and how to change the increment to 10 times instead of increase by value
(2,686 Views)
Two approaches come to mind.
1)Add an offeswt constatnt to all of the readings associated with the signal you want to shift.
2) Duplicate the Y-scale and associate your plot with the new scale. This approach is probably easier.
Ben
(2,685 Views)
But the first approach that you suggest is apply to *all, so it can't solve the problem
and second approach i can't do that, becos i wan to make the front panel look like oscillescope
(2,685 Views)
Idea 1 was
"Add an offset constatnt to all of the READINGS ASSOCIATED WITH THE SIGNAL".
Not all.
Ben
(2,685 Views)
Post an IMAGE of your code and I will take a quick look and make a suggestion.
There are function on the waveform palette that will do what you want.
Ben
(2,685 Views)
i get what u mean,
and going to try it soon
(2,685 Views)
Fine.
Please post an image of your final solution to help others in the future.
Ben
(2,686 Views)
