Plotting of Waterfall in Lab View From The Continuous Data Stream Coming From Interfaced Software RTSA Suite Pro
I am using build array to collect several points. Similarly, like you used it as shown in figure below:
Message 21 of 22
(220 Views)
Hi qureshi,
No, you don't collect several points!
All you do is to read the current spectrum from your device and plot this one (1) spectrum on your graph.
You need to collect several spectra (aka "from several iterations") in a 2D array!
I repeat (for the 3rd time):
You need to collect several messages/waveforms/spectra in a 2D array (using a shift register and BuildArray) to get your desired spectrum view on the intensity graph…
Message 22 of 22
(214 Views)
