Plotting two values on a graph
I'd like to plot temperature and humidity on the same graph, every 500ms.
What is wrong with my code?
Please, help!
Kind Regards,
Balázs
(6,360 Views)
Hi Balázs,
Basic LabVIEW knowledge:
1. Open the context help (using Ctrl-H)
2. Move the mouse over the broken wire and read the context help. Now you know what's wrong.
3. Move the mouse over the XYGraph terminal and read the help. Now you know which datatype that graph expects instead…
Simple solution: replace the XYGraph by a waveform chart.
(Think about why that solution works!)
(6,349 Views)
(6,314 Views)
Personally, I would go with a waveform chart.
(6,288 Views)
Hi there,
Well, is it possible to plot multiple waveform real time on the same waveform graph and see the data of all time measured?
(Time of acquisition is unknown)
Kind regards,
Balázs
(6,195 Views)
Accepted by topic author LTBALAZS
Hi Balász,
Yes.
and see the data of all time measured? (Time of acquisition is unknown)
Yes and no.
Yes: you can collect all data in arrays and plot them.
No: somewhen you need too much memory to hold "all data" and the graph will be very slow when handling large arrays…
(6,190 Views)
