Plug 2 instruments in diferent channels with instrument I/O assistant
Probably it's a pretty simple question but i just can't do this... I'm trying to get data from 2 instruments with a Kyowa UCAM-20PC which has 30 channels. I can get the data using 1 channel with 1 instrument, but I have problems when I try with 2 instruments,  labview always gives me the data of the last plugged channel, even sending the right command and openning 2 separateds instrument assistants for each instrument.
(2,440 Views)
It seems like labview just read the data, even without a command, that's why I always get the data from only 1 channel. If someone could help me i'd appreciate that.
(2,414 Views)
