Plugin - Vision Library
Hi Everyone!
I need a little advise! My Plugin VIs call Machine Vision VIs. All of my plugins are in a separate llb. As I build an exe, the LV RTE says missing componets are the MV vis. Could you tell me, how can I include these VIs into one llb. If I can, I would attach this MV.llb to my exe. That would be great!
Can I create a source distribution from National Instruments//Labview2009/vi.lib/Vision folder? and use it as a source distribution?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,030 Views)
Hello Durnek,
From what I understand you need to use a Vision Run-Time Engine(same version that was used to develop the VI). To instal it, your application will also require the Vision Run-Time License.
Related links:
http://digital.ni.com/public.nsf/allkb/3EB8C8AFC1593B4A8625712E0002869B
http://digital.ni.com/public.nsf/allkb/70293C1708FE3E7C862575EF007474EB
If you find that you wouldn't like to use the licensed run-time and that there is a way do implement your VIs without Machine Vision library, I can help you to achive that.
Regards, Peter
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(2,983 Views)
