Plugin for Director; Work Around
Is there any Macromedia Director Plugin for LabView available?? Are
there any programs, work arounds out to use LabView for educational
purposes? What I mean is letting run the LabView program in the
background (only calculating values) and to access it from outside
(in/output) through Director, Authorware or other programs.
Thank you a lot!
Tobias
(2,508 Views)
Hello Tobias,
You can definitely use the Macromedia Flash or similar softwares inside LabVIEW, that will help you in doing some work in the background and play the flash movie in the foreground. One basic example showing Flash inside of LabVIEW is Labview with Macromedia Flash
Also, there is a another strong feature in LabVIEW that might be of help is creating DLL's that you can call in any other program to utilize some of the powerful functions of LabVIEW.
You can get more information about NI in reference to Academics at http://www.ni.com/academic/
I hope it helps,
Rajiv
(2,508 Views)
