Plus Equal in Labview?
I wonder if there is a Plus Equal Funktion in Labview like I can Programm in C?
Message 1 of 8
(5,405 Views)
"+=" works on variables. In LabVIEW you almost never need them. Think dataflow. Provide an example where you think you need "+=" and we can discuss that example.
Certified LabVIEW Architect
Message 2 of 8
(5,386 Views)
Or for C programmers: Every operation in labview works like "+=" in C.
From this point of view, there is a lot missing in C 😋
Message 3 of 8
(5,381 Views)
That's a good point. Its built-in:
Message 4 of 8
(5,376 Views)
Thanks for your help. The example is attached below.
Message 5 of 8
(5,374 Views)
Accepted by topic author Spurbruenette
The question and the answer:
Use a feedback node (or shift-register).
I changed the value of the constant in your example. If you want to us the constant to initialize the indexing, you can do it like described. Or just not connect it if it shall start at 0.
Message 6 of 8
(5,361 Views)
Thats what i needed. Thanks for your quick help!
Message 7 of 8
(5,357 Views)
Increment (+1) is the closest i think.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(5,328 Views)
