Pocket mca 8000a
Hello.
I'm working with pocket MCA8000A for Particle counters calibration. I'm facing problem with DATA acquisition between my laptop and the Mca, red Light not blinking, I'm using win7 32 bit, usb to serial port converter, can you Please reply me email address chintadivyakiran@gmail.com
(3,512 Views)
1) You posted in completely the wrong section of the forums. Assuming that you are trying to use LabVIEW to do the data acquisition, you should post in the LabVIEW section of the forums, not the board where people can give feedback on the forums themselves. I have reported it to be moved to the appropriate board.
2) It is very unlikely you will get responses by email. Most people will respond on the forums, however.
3) You are likely to get more help if you provide a more detailed description of your problem and also post the code you have written so far.
(blog)
(3,508 Views)
