Poeblem on Open Database
hi all,
here is the problem, I used the Database Connectivity Tool to open a Database, which is based on Microsoft Access. Normally, the program can open the database successfully, but some times, like 1 out of 10, it can't open the database, this issue happened randomly and the error code is so weird, like "-2147467259", I have tried to search this error code in Google, but nothing has been found.
When this problem happened, I can't open the database anymore, until it dissappeared by itself.
Can anyone know how to solve this issue?
Thank you guys in advance.
Louis
(3,028 Views)
Hi Louis,
There's plenty of hits on Google, you just have to search for 2147467259 (instead of -2147467259).
It doesn't seem there's an obvious single problem leading to this error, but probably you'll find some things to try over Google.
Sorry I can't be of more help,
Daniel
(3,009 Views)
When searching for ADO related error messages, I generally modify the error out cluster of my top-level vi to display hex instead of decimal; most ADO errors are found via Google using the Hex value rather than the decimal value.
-2147467259 = 0x80004005
search for "Access 80004005"
(2,995 Views)
(2,969 Views)
