Point me in the right direction please
I am querying a device for its settings. The device will return a code. What I would like to do is from the returned code assign to this code a piece of text (ie. "the instrument is on" for 1 or "the instrument is sleeping" for 2).
How do I do this?
Thanks,,
Nevica
(2,992 Views)
It seems to me you are describing an Enumerated type. Use the enumerated type as an indicator and pass the code to the input. But that really doesn't give you a "text" string. Do you really want the result to be a string? That can be done using a case structure, or creating yourself an array of strings that matches the code and then using the returned code to select the index of you array.
(2,985 Views)
How do I index an array. I think this is what I want!!!
Nevica
(2,981 Views)
The simplest way...
(2,973 Views)
Thanks, thats how I imagined it would work. But how do I create the 1 by 3 indexed string matrix (the purple box). I cannot find this anywhere. I am searching for indexed string and I cannot find in example finder!!!
Nevica
(2,970 Views)
Place an array constant and a string constant on the block diagram.
Now drag the string constant into the array constant with your mouse. It should turn from black to pink.
Now you have created an "Array of string" constant.
(2,967 Views)
Accepted by nevica
Aha, that's how its done. thanks.
(2,964 Views)
