Point size.
Is it possible to change point size in Waveform Charts or XY Graphs. An how is this done.
(3,787 Views)
Hi
As far as I know, you could set the point size just by changing the line width. There's no other way I think.
Just right-click a signal on the plot-legend and select line width in the context menu.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,782 Views)
It works fine.
(3,774 Views)
