Pointer to structure in parameter list of DLL
I want to use the CALL_LIBRARY_FUNCTION to access a function in a DLL
which returns a pointer to a structure in its parameter list. How can I
access this structure under LabVIEW 6.02? What is the parameter type I
have to select in the CALL_LIBRARY_FUNCTION configuration window - there
is no STRUCTURE or CLUSTER entry?
Any help is very much appreciated. Thanks, Frank
(2,737 Views)
You may select "Adapt to Type" as a type of the parameter of the function, and then connect appropriate cluster to the output of the "Call Library" node.
Oleg Chutko.
(2,737 Views)
