Polar Graph cannot handle Waveforms in NXG 3.0.2
Bug got probably introduced in NXG 3.0.x, since it still worked in NXG 2.1 as long as I can remember.
See Snippet and corresponding front panel. Seems that something is going wrong with the dt value.
(2,992 Views)
Hello schoffel,
Thanks for pointing this out. I tried it in my side and saw the different behavior between 2.1 and 3.0.2.
I have filed Corrective Action Request (CAR) 736432 to address this inconsistency.
(2,961 Views)
Does wiring a waveform to a Polar Graph have some notable value for you? Would it be harmful if we disabled this capability?
(2,926 Views)
Hi, this was actually very valuable. The scenario is the following:
We are collecting data from a distance sensor dependent on the rotation of a shaft. The output is an array with the data for all angle values (with a varying Delta). It is therefore possible to have for example 3600 values with a delta of 0.1 degree for one rotation of the shaft. The trick was now to set dt to 0.1 to scale that data to a total distance of 360 data points (and thus one round in the polar graph).
Maybe it is a misuse of the polar graph but perfectly working for us.
Felix
(2,923 Views)
Sounds like enough of a reason for us to correct the issue properly. Thanks for the info!
(2,912 Views)
