Polar plot crashes LabVIEW 2013
I am working with polar plots to plot my pressure and temperature values to plot on circular grid. But i am facing labview 2013 crash everytime i run my VI. Can you pls let me know why am i facing this crash issue and whether the same can be done wth XY chart, if so solution pls...
The VI is attached and this is a template VI. The loading and removing of template VI on subpanel is handled properly and even stopping of this template is working fine.
Praveen
Praveen
(2,745 Views)
Nobody will be able to test your VI, since all sub VI's and typedefs are missing. If you want us to look at it, please post a working (well, crashing) VI that does not any of your sub VI's or controls.
You said loading, removing and stopping works fine. But if you can stop it, you must be able to run it, but you say it crashes everytime you run the VI?
When does it crash? How does it crash? How long does it take? What does the crash report say? Etc.
(2,700 Views)
