Polarimetric Sensor
I had posted this earlier but apparently there was a problem with the attached VI. This si the corrected version and will open in LabVIEW 8.
Please refer to the attached VI and the excel sheet.
As I run the VI and vary the pressure through the dial, SOP values are generated and plotted against time. Now as soon as the SOP value crosses -0.21, an alarm goes on. It switches off when I lower the pressure. I want to calculate for how much time the alarm remains ON.
Secondly, the generated SOP values correspond to certain pressure values as stored in the excel sheet. How do I compare the generated SOP with the pressure values. Basically I want a graph to show me what is the corresponding pressure. Right now I am directly plotting P v/s SOP in the VI. But in reality, I will just know the values of SOP and will have to what pressure it corresponds to. Moreover I have to pass this info to a program in matlab. So how do I achieve this??
Dhiraj
(3,106 Views)
And here is the excel file.
(3,105 Views)
Did we address this in another thread?  If so, let's use that thread exclusively for this.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,082 Views)
