My application has many windows open simultaneously (flexible, configurable data display, each running in its own thread). In previous versions of labview, I used the fp.frontmost propery to arrange the window stack periodically. This is clumsy, and the new Floating Panel feature significantly cleans up the window management.
However, I need a way to know which window the user last activated when all open windows are set to 'floating'. I used to poll the fp.frontmost property, but this is no longer an effective way of doing this, since no floating window shows as frontmost. Ideally, a 'front panel activated' event would work, but that doesn't exist. Is there another way?
Thanks!
