Polymorphic selection
If a polymorphic vi has ten function is there a way to select correct function base on user input without a case structure?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
(4,023 Views)
A ploymorphic VI is the one that "can adapt itself to diffrent data types".
So why the case structure is required? You have to select the option "Automatic" or Auto and just wire the input...
Regards
Guru (CLA)
(4,011 Views)
hmm, the auto option sounds interesting.
Yik
(3,990 Views)
You do know there's a manual right?
(3,978 Views)
I knew about the auto option, but I just never connected the dot.  Anyway, I can't use the auto option, since the input for all of my instances are of the same type, only the outputs are of different type.
Yik
(3,972 Views)
It would probably be best to keep this discussion in one place so people know what this is all about.
(3,970 Views)
I split that out, because I thought it is a side question, but I will try to keep it together next time.
Yik
(3,965 Views)
