Polynomial Equation for converting voltage to temperature
I'm using Labview Express 7.0 and I would like to know how to convert voltage to temperature.  The program says i need a polynomial equation to do this, I'm not sure what polynomial equation i need.  Can anyone please tell me some information regarding this equation.
(4,187 Views)
A few questions so that we may help. What are you measuring the temperature with? What is the program that you are refering to that requires the equation? In the case of thermocouples, the various types (which reflect the different materials used to make them) have different temp vs voltage curves. Some may be relatively flat for part of their range others describe somewhat of a curve. The mentioned polynomial will be obviously different for the different types. If you are using a thermocouple type of element a google search for the characteristics for that type may give you what you need. Otherwise, providing us with the info for the above questions will help us point in the right direction.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,182 Views)
I'm using a Typy K thermocouple and the Measurement Automation Explorer asks me for a polynomial equation when i try to set the thermocouple up with the daqmx board.
(4,178 Views)
I would say that you should get the equation from the thermocouple manufacturer.  They are the ones that designed the device and they should know the equation for converting voltage to temperature.  Look in the data sheets or spec sheets for the thermocouple.  There should at least be a graph of voltage vs temperature.  If no equation is listed, call them for one.
- tbob
Inventor of the WORM Global
(4,168 Views)
From the LabVIEW  function paletteunder
ni measurementts--data acquistion---signal condtioning
use the vi
convert thermo couple readings .vi
just pass the right parameters.  Should work
(4,162 Views)
Thanks, that helped a lot.
(4,145 Views)
