Polynomial Fit with Slope and Intercept outputs
Folks,
I have a project that requires linearizing the output of a high voltage amplifier using the 2nd order Slope and Intercept equations with 20 points.  Unfortunately, I need to use a Poly-fit function rather than a Linear fit.  I admit, I really don't know the difference, but the designer of the PWA insist that only a polynomial fit with 2nd order Slope and Intercept calculations can be used.  I have Labview 8.2 Professional, but I do not have a V.I. that has this function.  Any suggestion or help is greatly appreciated.
Rick H.
Message 1 of 8
(6,863 Views)
Sure you have it! 🙂 Two possibilities:
  1. Curve fitting express VI (configure for polynomial fit on the express panel)
  2. General Polynomial Fit VI
Both are from the "Mathematics..Fitting" palette and are easy to use. See how far you get.
If you still have problems, attach a simple VI containing typical data in a diagram constant.
Message 2 of 8
(6,859 Views)
Thanks, but no dice!  Both Polyfit VIs that you suggested do not have an Intercept or Slope output.  As I mentioned in my first email, only the linear fit has this output.  Please advise
Rick H
Message 3 of 8
(6,850 Views)
Well, a second order polynomial does not have a "slope" per se. You just get the coefficients of the polynomial.
For second order, just look at the array of coefficients.
y(x)= A + Bx+ Cx^2
  • Element 0 is the intercept (A)
  • element 1 is the linear term (B)
  • Element 2 is the quadratic term (C).
All clear? Since the polynomial fit can be used for any order, it would be inconvenient to create seperate outputs for each coefficient, since their number depends on the order.
You can use the coefficient array directly as input into "polynomial evaluation" to calculate the y for any x later. 🙂
Message Edited by altenbach on 01-24-2007 11:13 AM
Message 4 of 8
(6,848 Views)
Thanks for the suggestion.  My knowledge in this area is limited at best and I appreciate your time in explaining this in detail.  I'll give it a spin.  Thanks again,
Rick H.
Message 5 of 8
(6,841 Views)
Hi
You have also the possibilty to calculate the polynomial fit and in a second step to derivate from its best fit result.
Message 6 of 8
(6,507 Views)
Well, this thread is almost 3 years old and I am not quite sure what you are trying to say here, because the problem seems solved.
What do you mean by "derivate"?
Message 7 of 8
(6,488 Views)
Yes surely, i have to implement a similar problem and maybe other person have interrest to see a solution. See the example
With best regards
Message 8 of 8
(6,478 Views)
