Pop Up Menu
Hallo,
I created a menu with four boolean buttons:
button1
button2
button3
[OK]
The button1,2,3 has two values, f.e. button1=false: sample button1=true: empty etc.
Since I only need button2 and button3 if button1=true, it would be very nice if they only appear if button1=true.
Does anybody of you know how to manage that?
Arno
PS: If you attach LabVIEW-Code please convert it to LabVIEW 6.1.
(2,843 Views)
You need to use property nodes and use the visibility property of it. Right click on buttons that you want to make invisible and wire a value of false to it. On click of button 3 pass value of true to both the booleans.
(2,837 Views)
