Pop up a running VI (not with SubVI)
Is there anyway to load a vi in 'running state' using vi server reference ?
Thanks.
(3,391 Views)
Yes, use can do with invoke node and vi server reference.
(3,386 Views)
thanks, I used this with FP open and im getting a vi pop up, there is one more thing the VI that pops up is running in a an odd fashion. Its running and not running, like switching states, and when I click on the FP the vi stops running all together, until I release the click.
(3,384 Views)
Post your vi. Can help you much better.
(3,373 Views)
Ok here's the VI.
(3,371 Views)
Ok I got it 🙂 i was using a case structure in the vi that I was calling, so I used a while loop with it. i guess it was polling the case structure.
thanks again
(3,369 Views)
Welcome..
(3,366 Views)
