PopUp menu part III
Hallo,
I want to create a popup-menu looking like the one in the attached file. It is almost finished, exept for one thing:
The upper two buttons are working just the opposite way I want. Pressing one should deactivate the other one. But now it activates the other one by deactivating the first one.
I think I have to negate something, but all my tries were unsuccessful.
Can anybody help? Btw, I use LabVIEW 6.1.
Arno
(3,718 Views)
Hello Arno,
instead ot the Negate you could use case statements with constants wired to the components of the cluster (like If Empty cyl. then sample=FALSE).
You can also use just one switch for both measurement modes. See the attached example. By using an enum you can easily extend this to more than two modes.
(3,718 Views)
Hello Arno,
example converted to Lv6.1 ...
(3,718 Views)
Hallo Gerd,
good idea. How did you realize that button? I can't find it ...
Arno
(3,718 Views)
Arno,
Notice that the cancel button only cancels the last action...
Wiebe.
"GerdW" wrote in message
news:5065000000050000005FBA0100-1079395200000@exchange.ni.com...
> Hello Arno,
> Best regards,
> GerdW
(3,718 Views)
The button has the boolean text visible (see gif). Right click any boolean and you can get labels for the on and off states.
Check out LV help under 'Boolean controls and indicators>labeling buttons'.
Fading out. " ... J. Arthur Rank on gong."
(3,718 Views)
I think you can do the whole thing a lot simpler using an event structure. You might also want to look at the radio button controls in \examples\general\controls\boolean.llb.
(3,718 Views)
