Populate a Ring or Enum Control from File (not at runtime).
I'm trying to populate a ring control (type def) but I've not found any way to do it.  I have an extremely long list that I would like to put into a ring control and I want to do this such that it is 'hard coded' in the ring control.  A delimited file (anything but a space) is what I would imagine should be easily imported into a ring or enum.
Does any one know how to do this or some other method for a long list of items?
(3,951 Views)
Hi Nathan,
read the file, convert it to an (1D string) array using SpreadsheetStringToArray and write that array into an property node "strings[]" of your ring...
(3,948 Views)
Your suggestion is done at run-time, as far as I can tell.  I do not want to require the file during run-time.  After importing I'm wanting to save the type def and then be able to edit the items in the Properties dialog.
I'm ultimately trying to create a library for a sensor that has a lot of register adresses that will not change on the device.  The register addresses are the items that I want to put in my typedef.  If the above is not possible, is there any other alternative?
(3,916 Views)
Is this any better?
https://decibel.ni.com/content/docs/DOC-22702
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,907 Views)
Am i missing something here???? Why couldnt you just import the file to the Enum and then create a type def from the one that is populated????
Joe.
"NOTHING IS EVER EASY"
(3,898 Views)
Creating a type def from the ring in Gerd's code does work.  Thanks both of you.  Here is what I ended up doing:
(3,879 Views)
