Populate combo box dynamically
I have a combo box which is populated from a cluster array which is unbundled to the element I want to populate the combo box with. There is multiple types with the same element such as
1 - 60mm
1 - 60mm
1 - 60mm
1 - 60mm
3 - 60mm
3 - 60mm
What I want to do is just show one 1 - 60mm and one 3 - 60mm and when selected will get the index value to be displayed with thos types only in a table?
I have not lost my mind, it's backed up on a disk somewhere
Message 1 of 16
(5,697 Views)
You mean you want to remove the duplicate elements?
Message 2 of 16
(5,687 Views)
Yes I want to remove the duplicates and when that element is selected it will load all matching elements
Message 3 of 16
(5,684 Views)
What is the output that you are expecting? the index of the matching values? number of matching values?
Message 4 of 16
(5,671 Views)
The output is being displayed in a table and I would like just to display all matching elements in the table
Message 5 of 16
(5,669 Views)
I am not limited to a combo box any other form of control like a combo box will also suffice
Message 6 of 16
(5,647 Views)
You can go for a Ring control. Still not able to understand "matching elements". Do you mean that other elements in the cluster along with "Type"?
Message 7 of 16
(5,637 Views)
My cluster has multiple elements with an ID Type Time Date Stamp and various other paramenters. Some elements have the same type for instance
ID  Type          Time Date
1   1-60mm   13:00 18/06/2014
ID  Type          Time Date
2   1-60mm   13:00 18/06/2014
ID  Type          Time Date
3   3-50mm   13:00 18/06/2014
I would like the combo box or ring control to display just one 1-60mm(no duplicates) and when pressed it will load every other element with type
1-60mm in my table
Message 8 of 16
(5,631 Views)
Here's how I would do that: (second case is 0, Default and it's just stright wire connecting shiftregisters)
Message 9 of 16
(5,620 Views)
Accepted by topic author PauldePaor
I just made a sample code to show one of the way to achieve what you want (To be honest, I did to refresh my coding skill). You can tweek to get it to a good shape.
Message 10 of 16
(5,611 Views)
