Populating Array
Try something like this.
Testing for exact equality on doubles can fail since each value may be represented slightly different but be very, very, very close to each other.
Also, I am not sure if the above logic is exactly what you are looking for but the concepts I illustrated apply your questions.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 14
(1,104 Views)
Hi Mark,
Thanks a lot for the illustration. I was wondering what you did for the false case.
Message 12 of 14
(1,080 Views)
For the false case I would want to skip over it and not change the output array. Like break and jump to the next index.
But if I just leave the false case empty and the tunnel unwired, I would get the broken run arrow unless I choose to use default if unwired.
Just wondering how I could wire up the false case to skip to the next index in the for loop.
Message 13 of 14
(1,073 Views)
If you are using Mark's setup, just pass the array straight through (input tunnel to output tunnel).  That way, you keep the value the same and keep it in the shift register.
Message 14 of 14
(1,067 Views)
