Popup help window won't display
When I run my application, Ctrl-H won't display the help window that is used
to display control descriptions. Does anyone know why this might be so? It
seem this feature was working fine in older versions of LabVIEW (4 and earlier),
but not w/ 5.0 & 5.1.
(2,971 Views)
Your problem with the help window has to be either a problem of your CD
- maybe a bad track on it - or an error while installing it.
I'm using a 3.1 student edition and a 5.1 full edition of LabView and
never had any problems with the help window.
Maybe in the 5.1 there is a preference or options menu-item within you
are able to switch help on and off or change controls - the 3.1 has no
such possibilities. Otherwiasae you should try to install LabView again
and test the help capabilities o
f the re-installation.
(2,971 Views)
