Popup menu in controls
How can I make popup menu of controls disabled for the user (especially for
waveform Graph or XY Graph).
In case it would be impossible how can I control Cursor and Scale legend
programmatically (visibility).
Gregor
(3,205 Views)
To disable all, go to VI Properties>Window Appearance>Customize and uncheck Allow Run-Time shortcut Menu.
(3,205 Views)
To programmatically control the visibility of the cursor legend and
scale legend, show the item, then popup on the edge of the legend and
Create a Property node. The node will now work the same as on any other
control.
Greg McKaskle
(3,205 Views)
That's it what I need
Thanks a lot
Gregor
Uzytkownik "Greg McKaskle" napisal w wiadomosci
news:3D93BB6C.3090205@austin.rr.com...
for
> control.
> Greg McKaskle
(3,205 Views)
