PopupMenus - Arrange Cluster.llb
Hello, I have got an interesting issue with the PopupMenus creation.
I want to have the cluster allignment options not like the PIC1.png, but like PIC2.png.
With the attached lib copied to "LV/resource/plugins/PopupMenus/edit time panel and diagram" folder it is achievable, but the functionality is not good.
I think the issue can be with the type cluster, but i don't know why. With another data type as Array, this approach is working.
Any idea where could be the problem?
Thank you.
(3,510 Views)
Hi Tibor,
Can you define the problem with more details?
What exactly is "not good"?
Btw. please don't attach BMP files with just renamed file suffix. Convert them to real PNG images! Do you see the difference in filesize?
(3,500 Views)
Dear GerdW
I guess that problem is that it does not work as expected - I've tried, and menu appears, but selection "Arrange Horizontally"/"Size to fit", etc. does not change cluster view...
(3,492 Views)
Hi GerdW, thank you for the picture hint.
The problem is that the menu appears one level up, that's good, but after choosing cluster align option the cluster remains the same.
If "Size to fit" is clicked, it should fit the cluster according to it's elements, but it doesn't.
(3,476 Views)
