Port and Memory Utilities for Windows AccessHW KnowledgeBase 2Q1FC3K8
I've been trying to install the AccessHW drivers for Win2000.
KnowledgeBase 2Q1FC3K8: How Can I Access Hardware Registers or Implement In Port and Out Port on Windows NT/ 2000? How Can I Read or Write Physical Memory?
http://digital.ni.com/public.nsf/websearch/E6415E8A8376F63D86256C46007592E8?OpenDocument
I get nonfatal errors when trying to install:
NONEFATAL ERROR AT SCRIPT LINE 1112
Unable to open destination file
And sveral instances of this one:
NONEFATAL ERROR AT SCRIPT LINE 1086
Cound not create file
Thanks for the help!
System:
Win2000
LabView7.1
Bill
(2,947 Views)
You do not need to install these drivers. As the app note says, you only needed to do this for versions of LabVIEW prior to 7.0. The In Port/Out Port functions that you have will work on NT/2000/XP.
(2,940 Views)
