Port opened with TCP Listen.vi continues to accept TCP Open Connection.vi calls after closed
Sarah,
Thanks!  I've coded a TCP Listener based solution for my application to get around the problem, so it won't be holding me back.  Just thought NI would like to know.
Message 11 of 20
(1,903 Views)
Hi, Jeff.
I'm glad you've found a workaround, and we definitely appreciate your willingness (and persistence!) to pursue this. Also, if you have some nice workaround code, you may want to post it so other forum readers can bypass this apparent bug until it's fixed.
Either way, have a nice weekend.
Sarah K.
Search PME
Message 12 of 20
(1,899 Views)
Sally,
Here's an example of a workaround TCP Server that only accepts one connection (using the TCP Listener insead of TCP Listen).
Message 13 of 20
(1,894 Views)
Sarah,
Did R&D find a fix for this problem?  Does a later version of LabVIEW fix this issue?
Message 14 of 20
(1,799 Views)
Hi JeffH4,
This issue has been reported and is under investigation by R&D.  I'm sorry for any inconvenience but I do not have further information at this time.
Elizabeth S.
Message 15 of 20
(1,777 Views)
Well, it's been over a year since the problem was reported.  Isn't there a Problem Report database that can be accessed to find out the status of the fix?  Or a keyword search on the same database?  Or is there no insight whatsoever from the forum users to the NI developers to document that this problem was even looked at by the NI developers?
Message 16 of 20
(1,760 Views)
Hi FMonkey,
Thank you for your simple instructions.  I was able to reproduce this error and filed a report to R&D (# 4BAHL189) for investigation.  Thank you for the feedback.
Elizabeth S.
Application Engineer
Message 17 of 20
(1,739 Views)
Hi JeffH4,
This issue has been fixed in LabVIEW 8.2 as I was unable to reproduce the same problem.  Typically, the report number is posted in a discussion forum when a bug in reported to R&D.  Unfortunately that was not the case in this instance so it has proven more difficult to track down the issue.  Again, I’m sorry for any inconvenience.
Elizabeth S.
Message 18 of 20
(1,736 Views)
It would appear that this issue has resurfaced in (at least) LabVIEW 2014. I haven't checked later versions of LabVIEW yet.
Message 19 of 20
(1,200 Views)
See discussion here: https://forums.ni.com/t5/LabVIEW/TCP-IP-feature-or-bug/td-p/832692
Message 20 of 20
(1,196 Views)
