Portable functions palette for source distribution build
I'm working on a Labview project which I want to distribute. The project contains Labview addons. How do I create functions and controls palettes so that they are portable and follow with my source code distribution. I assume my source code distribution needs to be installed to user.lib. I'm using Labview 8.0 and Project Explorer to manage the project.
If possible I want to add items to existing labview menus such as File IO menu etc. In addition I want to have a second copy of all my function in a separate root level menu.
Example:
/Programming/File I/O/My File I/O menu
/Programming/File I/O/My File I/O menu/Read my file
/Programming/File I/O/My File I/O menu/Write my file
/Signal Processing/My Signal Processing menu
/Signal Processing/My Signal Processing menu/My filter 1
/Signal Processing/My Signal Processing menu/My filter 2
/My Signal Processing Toolkit menu
/My Signal Processing Toolkit menu/My File I/O menu
/My Signal Processing Toolkit menu/My File I/O menu/Read my file
/My Signal Processing Toolkit menu/My File I/O menu/Write my file
/My Signal Processing Toolkit menu/My Signal Processing menu
/My Signal Processing Toolkit menu/My Signal Processing menu/My filter 1
Tomi.
Tomi Maila
Message 1 of 1
(2,209 Views)
